So i've got my 03 300ex about 90% dialed in but it still acts like its flooding if i shut it off and try to start again. The only way i can get around it is to shut the gas off 1st and let the engine die. It sounds to me like a float valve issue but ive cleaned it with a q-tip and used 2 different valve needles but the issue persists. These floats are not adjustable so i was hoping to find out a way to test its functionality to see if this is indeed the problem. Thanks in advance guys
In the bowl of your carb is a tiny tube that sticks up where gas can flood out of a tube in the bottom of the carb. If your carb isn't leaking out of the bottom then the tube passage is either not ckean or not flooding. Clean the tube by blowing air through. Then if it leaks out of the bottom it's flooding.
It's very important you clean the tube to keep gas from getting in your oil so you may want to smell your oil for gas and see if it needs changed.
I don't believe you can replace the brass seat that the float valve sits in on your carb you can try to out toothpaste or brass cleaner on a qtip and ckean it but lots of times that doesn't work either so you may need to buy a new carb if you can't get that fitting clean.
If you blow in the fuel inlet with the carb upright it should blow right through, when the carb upside down the float valve will be closed and you will not be able to blow through the inlet. That’s basically how I check them.
But, sometimes they will leaky slowly and it’s hard to tell, all you can do is clean the seat the best you can and replace the float needle, if that doesn’t fix it then the carb is junk.
