I would not know. Instructions never specified.Are those rotors not directional as well?
Sent from my SAMSUNG-SM-G870A using Tapatalk
Thanks for info.Idk, but on cars the slots suppose to lean towards the rear. Video shows your right side okay but not the left. Probably don't make much difference on a atv but idk. If if was me I'd flip it so they match.
There was talk of rotor direction in one fish's build threads...Are those rotors not directional as well?
Yes, the kit for the 300 is no longer made so you use the foreman kit on a 300 which I did.Oh i gotcha, didnt you install a disc kit of the 300 ?
I don't think it matters on single layer drilled, or slotted disc, but.... On vane vented disc, your right Sam. My real concern would be the grime and dirt. (Sandpaper action on a mud bike)
Not sure again if it matters since these are not vented. And not sure on your photo, it shows front, but is that the left or right disc? Also I know that major auto manufacturers also disagree with the rotation. It seams 90% agree, but Brembo is the other 10%. Either way for personal preferance I'd make them at least match, and most likely lean towards the rear.Rotors (discs as we call them) go whichever way will remove gases (caused by heat) the fastest. On my disc kit the vent holes in the ‘rotors’ were diagonal. After some research the correct way was as you see in the picture, I’m no artist but I’m sure the picture gives you the right idea LOL
