1 - 12 of 12 Posts
Looking at upgrading my tires and wheels on my rancher 420 sra. I'm guessing the suggested 2+5 and 5+2 is somewhat wider than whatever the factory offset is. I need to fit my rancher on either a 4x7 trailer or in the bed of my 07 tacoma. Anyone with a rancher with aftermarket wheels able to fit their fourwheeler into one of these or tell me how much wider the wheels make it from factory?
I didn't measure mine before I installed my ITP's, but can measure with the aftermarket wheels for you tonight. It doesn't look much wider.
I have an 09 rancher AT IRS And I have 14" wheels with 27x10x14 zillas on front and 27x12x14 on the rear!! Will NOT fit between my wheel wells on truck anymore (atleast not the back tires) They are alot wider!!! Stick out almost 4" from the fenders on the rear!! I pretty much don't stay clean anymore when riding, but they look SWEET!! About 51" to 52" wide at rear!!
here is a pic..
Vehicle Car Automotive exterior Automotive tire Tire
Here is a rear pic..I had just got them and had not put on fronts yet..lol
Land vehicle Vehicle Automotive tire Car Tire
What offset are those rears? With IRS, they should be the same offset as the front (unless you opted to go with a wider rear).
Not too sure.. I ordered them form onoffroad.com.. I called them and told them what I had and my conserns. The guy said that the offsest were not quite the same as stock, but assured me they would work... I thought they stuck out a bit too much myself, but I don't mind the wider foot print. Since the bike is narrow to begin with, and now it sits a bit higher, and the wider rear makes it more stable..
Checked my order form, and the wheels are wider in back also. The tires are 27x10x14 front and 27x12x14 rear.. I probably should have ordered 27x10x14 all 4?
Nah, you want 12's on the back and narrower on the front. Wider is better when it comes to stability...I think you did good.
1 - 12 of 12 Posts
