1 - 9 of 9 Posts
how long do clutches normally last? i have a 98 300ex im putting back onto the trail after a long break and it still has the stock clutch..seems to work fine now but im just curious what you guys have to say
Agree^^^^^!!
o wow i think mine is ajusted all the way out
All the adjustment on your clutch cable does is to adjust the free play in the clutch cable. It doesn't have anything to do with how bad your clutches are worn or slipping, unless you adjust your cable in to where it is partially disengaging the clutches. Then it will cause your clutches to slip. All the cable does is disengage your clutches.
Agree^^^^^ with Helmut..
HEY 300!!! Your clutch is just fine little buddy!!! leave it just like it is for the trip down.
1 - 9 of 9 Posts
