1 - 20 of 62 Posts
i have a 95 300ex with a performance cdi and i put a fmf megamax 2 exhaust on it i went from a 122 jet to a 125 i also removed the airbox lid and wraped the header pipe with that header wrap for cars and after about 10 min of riding i cant get my leg within a foot of the exhaust because of the heat i know it should be hot but not that hot i was told i was to lean because it also backfires a tiny bit when i let of the gas do i need to go up a jet size or could it be something else ?
Yeah it's lean.Try a 130 main and a 40 pilot.
ok ill try uping (spellcheck?) to a 130 and ill change the pilot to a 40 thanks ill let you know how it goes
Yep, too lean.
Make sure your pipe isn't leaking where it bolts to the head. A leak there or a crack in the pipe will make them backfire or pop.
There isn't one where it bolts, but about six inches out I spotted a small leak. I asked my dad if he could weld a small patch there, but he said after it breaks in it would probably go away
I had a pipe crack in the bend where it comes out of the head and curves back around and it would backfire when I let off the gas or when the engine was holding it back down a hill, it would pop.
Yeah fix the leak.I just went through this with my 250.A small leak will make her pop.But you could also be a little rich.It will load the pipe up with fuel and cause it to explode as a compression would in the cylinder and it back fires.
My plug is still white, but I just read in one thread today to change the spark plug after messing around with the carb. I'm still running the same plug...
I agree.Change the plug and see how it is.
umm my pie like that u cant get withen a foot of it when i run for about 10mins but i deal with it
it takes all of 10 min to put in a 8.00 part Jon. that will save you hundreds in the long run. Do it right, I can honestly say that, I learned from my mistake. learn from yours. buddy
Yeah I'd say it was lean all this time.Thats why it blew up.
no it was vary rich so we lean it out a little but my pip would burn though my pants if i touch it
You had issues if it got that hot buddy. I have my pipe header wrapped it gets hot but I can touch it without it scorching me.
I definitely think that the monster had some issues if it got that hot. mine used to but I rejetted and that cured mine.
1 - 20 of 62 Posts
