1 - 9 of 9 Posts
Does anyone know if Hot Cams made a cam for the 300 4x4?
If they use a 300ex cam yes.
Ok thank you!
Now, I don't know how true this is, but I was told that you could put a 300EX head on the 300, but you have to order a reverse grind cam from Web cams for it to work. The 300 has 2 valves and the 300EX has 4 valves, so that would be a little improvement if it works.
I'm pretty sure the 300 cam is different than the 300EX cam.
Yep two completely different engines. I looked at web cams a couple of weeks ago and if I remember right the low end cam called for high compression piston and new valve springs.
I looked at Web just the other day and from 92 up you had 3 choices. The first choice was a drop in cam which near as I can tell would be about the same as the 88-91 cam. Then there were two more choices after that both requiring piston and springs.
1 - 9 of 9 Posts
