1 - 9 of 9 Posts
hot cams are out for the 700xx i seen them on ebay today im thanking about trying one
They are not available unitl 4/15/10 from Hot Cams. Use cation when buying one off of ebay. I find it wierd that ebay has them available before Hot Cams.
Do not go above a stage 2. The stage 1 will give you noticeable power gains over the entire RPM range, made to use stock exhaust/intake. Stage 2 leaves the bottom end about the same but will stretch your arms above 5000 rpm. That is made for a quad with minor modifications such as pipe and air filter. Stage 3 is for a completely built motor.
do you thank there worth the money
Oh hell yeah. Get a stage 2. I have a Stage 2 in my 450 and all I can say is WOW. When i put the cam in, it was like a whole new machine. It pulls so fricking hard.
Here's a dyno chart for the 450 motor and a stage 2 cam.
Discussion Starter · #6 · (Edited)
Great now I can't wait till 4/15 lol. I just talked to my Honda shop about putting it in they said it will run about $250 for them to put it in and it will not void my warranty if they do it
NICE!!! Warranties are great!
You will need to add more fuel on your juice box
Yeah, they could be counterfeiting them. I saw were the Dynojet Jet Kits were being counterfeited. Check out this link.
http://www.dynojet.com/whats_new/PressReleaseKnockOffJetKits.pdf
1 - 9 of 9 Posts
