1 - 14 of 14 Posts
Y’all won’t believe me when I say this, I have owned 6 300 Honda’s in this year alone and never have managed to ride or even start one due to problems that’s apparently over my head. I have 1 left and want to keep it but can’t get it to run after I swapped a diff motor in it, the previous motor ran but smoked like a jet
Welcome!
Wow you had quite a run at them TRX300–don’t give up. These are relatively simple machines but they have very specific needs—most parts will interchange but not all will work!!
Check my links below you need to locate two manuals 88-94 and 95-00. You have to know VIN or engine number to get a good start
Welcome!
I have the engine number off both the motor I took out and also off the motor I put back in it, the motors are the same size however they are made different slightly
if your getting spark at all ?, fuel ?, and compression is at least 100 psi ?, and the timing is right ?, then by all rights...it should run !.
Welcome!
TE14E-80xxxx cross ref to 1988 trx300
Now you know you gotta first year TRX300 you can jump on the Shadetree project thread!
the writing at first, i seen before, when ya 1st., posted. any chance ya can explain it to me.
look's like a trade-mark, symbol is at the top, behind what looks like an E, more or less.. just curious..
do's it have to do with scottish?
Seems to be a formatting issue with his single quotes. The symbols appear every time an apostrophe should be there. (Ex: Ya'll, won't, Honda's, that's, can't)
Can't tell you why though! No clue why it happend :smile
It has to do with his keyboard language settings.
it seems European, maybe, south africa. i dunno, bout that last one... :smile
1 - 14 of 14 Posts
