before cleaning carb, did you make sure things up stream are good
like clean fuel tank, peacock, fuel line, fuel filter, is FUEL fresh and good
as if NOT, cleaning carb might have been a waste of time
modern ethanol fuel can go bad in a few weeks, so if this atv sits often (and you didn;t list yr of machine)
its real common for fuel related problems to be up stream of carb
PLUS< HOW did you clean carb can be a issue too, ethanol will coat things with varnish like coatings that spraying and soaking with carb cleaner will NOT remove, and partially blocked passages can cause funny like running issues
is your air filter good, is the boots to carb GOOD< no pin hole dry rot or leaks?
HOW does the spark plug look?
