The first pic looks like a lone ground wire
Third pic goes to the neutral and reverse safeties
Please download the service manual there are many diagrams of wiring and hose placement
Does this Foreman run?
first pic is for spark plug coil ground. but it should be green ?, second pic is the sub-connectors that run to the third pic, where those connect to the neutral, reverse switch, and your oil temp sensor. as advised above ^^, down load the service manual from our site here.
There's also a cover for those safety switches you either removed it or it's missing. Plenty of those available you need one to keep your foot from breaking those connections
that and sticks pulling them lose..lol
Reactions: Goober
Ok nice thanks Mac. Mitch you can use the link I posted to open up the manual if you're using an iPhone click the three dots in the upper right corner and click "open in a new window" it will download faster.
Try to get all the wires back into place before putting in a new battery or cdi. Foreman ignition wiring is different than the base model wiring.
You may find it easier to remove the front fender to do this, if you have the work space
