Hi I have a TRX300 that is driving me crazy. the bike was running perfectly until a few months ago when it just started spluttering, exploding out of the exhaust and stalling. Initially we thought that is was a fuel issue so we changed the filter, still the same result. We then cleaned the carb 3 times with no change. We have now installed a new carb and another new filter and changed the fuel and it's still exactly the same. I read another forum that said try changing the spark plug but again this has made no difference. If you start the bike it will idle quite happily it's when you increase the revs that the issue occurs. Sometimes if you're very gently on the throttle you can ride the bike but it has lost most of its power.
Can anybody give me any advice on what could be causing this?
Thanks
Thanks
