1 - 17 of 17 Posts
ok guys i checked my snorkel for leaks with either and there are no leaks in my snorkel i took my atv to the river yesterday and when i hit the water stayed on but then i hit a deep hole where the water when to my seat and it just cut off on me again so later that day i took it home and took a hose pipe and shot water on all eltric items to see if it cut off on any of the wires but it didnt cut off like i supposed it might of so now im stuck here dont know what to do to my atv to fix the problem and on fuel injected where is the carb line? and stuff:wacko: i got this deep cut off instantly
Hardin Beach 4-Wheelers's Photos - Hardin | Facebook :icon_ nono2:
do you have your airbox sealed with silicone? And running water over connections will not get everything wet like a submerging will. water has to flow with gravity.
i would say you got a air leak somewhere..although i don't know crap about fuel injected carbs..other than they suck !!..did you also check the drain plug on the bottom of your air box ?..is it still on ?
how did you bild you snorkel ,,,can you just put on on what dio you have to do other than make it ... have you put anything on sparkplug boot to help water going into thare ?
yea spark plug don't get wet intill my atv cuts off in water and the exhaust is under which takes in massive amounts of water...
you need to check your oil for water in it..if you stalled in water that was over your ex..i bet your oil is full of water.
Id suggest you snork your ex. pipe as well once you get going again
i had a local honda mechanic put it on. and hes worked on quads for 12 years now.
i've worked on atv's for 14 yrs..and i still learn stuff every day...i don't think the mechanic covered something right ?..or not at all ?..water is getting to something..causing it to shut down. more than likely..it's probally getting to some wires shorting your ride out..you may want this mechanic to look at this for you.
I don't think there's any kind of drain or vent hose on the throttle body, but make sure the clamps that hold the throttle body on are tight.
1 - 17 of 17 Posts
