My Recon shut off while driving. I was able to get it to start and drive back home. The next day I tried it again and only made it about 300 yards before it shut off. Then it stated again and I tried to drive back but didn’t make it far so I pushed it home. It would start but I didn’t want to run it anymore that day. Now it won’t start at all. Please help.
welcome to the site
NOW< some more info
how often do you use this atv, does it sit a LOT
if it sits a lot, its very possible your fuel is BAD, ethanol fuel can go bad in a few weeks
so,
maybe start with draining the tank, make sure its clean inside too when drained
then check and make sure your fuel peacock is working and flowing well
NEXT< if it was me I would replace fuel line from tank to carb, cheap easy way to know fuel line is clean and not varnish coated!
THEN< its time to clean your carb, as sounds like you have a fuel supply issue, and by cleaning tank, peacock,line and now carb, then starting with new fuel,
you rule out all these issues as possible causes to your problem!
and most likely will resolve your issue in the process
also, if this atv sits often, I HIGHLY suggest buying NON ethanol fuel for use in and and TREAT IT as well!
Check for spark using a new, properly gapped NGK spark plug. Let us know what happens...?
Were you running the bike without a battery in it? Or running it with a junk battery in it?
What year is it?
This atv is a 2006 and gets run almost everyday of the year so it has fresh fuel in it. I will start checking lines and stuff when I get home. I also forgot to say that I just pressure washed it before this started happening. It wasn’t anything major just knock a little mud and dirt off but it just seems odd.
if im not mistaking, pressure washing can have drawbacks, depending where you wash.
pressure washing can be very bad on atv's
yes it sure removes mud and junk, but it also forces water into places it shouldn;t be
and can ruin bearings and seals
if these issues started after power washing, I'm guessing you got water in an electrical connection and is causing you issue's
I would check all connections and even clean and dielectric coat all connections, start with spark plug cap, fuses, and then CDI and other major power points, and keep going till you find the one!
I will again say I would never rule out fuel, you can BUY bad fuel, so it doesn;t have to be fuel sitting about a long time for it to go bad, can also be bad from the get go, just a tad too much water in it or mixed with older fuel at station and BOOM you have NEW issue's
but this sounds more like a power washer issue,
and you just got some electrical part wet that should have!
Maybe even pull your CDI and pout it in a baggie full of dry rice for a day or so, or place out in the sun to dry insides better!
