New to forum and ATVs in general.
My grandson called to tell me his Honda Recon ES had a problem:icon_ nono2:.Turns out he had ridden out a little way from their house to watch deer.When he started to leave the trans. would not shift to N so he could start.Turned on switch and green light blinks with a slight whirring noise when either up or down buttons were pushed.Switched it off and back on and green light came on solid until I tried to shift it.It then began to blink and still no shift.
Got it towed back to the house and hecked battery voltage. 12.4 volts.Hooked to 1.5amp slow charger which lit the yellow light meaning it was taking charge.
Is a low battery the only problem or should I check elsewhere for him?I feel short trips are robbing the battery more than it is recharging but just guessing at this point.
Thanks to all replies
