Hey Guys,
question for you guys. I have a 98 Honda Recon 250 TM. The engine locked up , and I went to replace it. The engine I bought was suppose to be off a 2000 TM but when I got it home, and ran the serial number it turns out it is off a 2002 TM. I have it in and I can't get it to turn over. I have put a new ignition switch, new starter switch (both were broken and needed replacement), I have swapped out the solenoid, check the fuse, done a cross jump and the starter will turn over... but I can't get it to switch on... what are the differences in the 98 and 2002 250's? Do I need to change the CDI to a 2002? Are they any different?
Any help is appreciated...
Thanks,
Thanks,
