I rebuilt the motor on my 06 honda rancher 350 es 4x4.if i go to crank it it says --- and its in neutral i know for sure.if i shift up 1 it says 4th gear.that is not true.if i ground the green wire with a red stripe the light turns green and i see a n. do i need to pull the stater cover and see if the gear positron sensor is broke? where should i start? i plan to fix this tomm. thanks :sad:sad
