Hi, I own a 2007 Honda Rancher which I haven’t used for 3 months and decided to move it and it will not start. When I turn the ignition key the dash lights up with the neutral light but I cannot hear any noises or ticking from the relays at the back or anything from the fuel pump. I’ve been chasing the problem to the fuse box. Found out there is no power to the ignition fuse (10 amp) but all the fuses are good and all the others have power. The only thing I could find out is that the red wire going to the ignition has no power at all and the red/black one does so I hot wired it and suddenly there is a tick sound from the relays but no fuel pump or starter turning over. Does anyone know if the red wire goes somewhere and can it be fixed?
