1 - 2 of 2 Posts
My atv isn’t 4x4 so the drive shaft in the back is the one leaking, I’m guessing it just needs a seal replacement so how am I supposed to pull the drive shaft out?
seeing how you did not tell us the FULL YEAR, MAKE, MODEL ?, i'm just gonna say this, remove the swing arm, drive shaft should come off the output shaft ?, once the cv joint is off the output shaft, replace the oil seal where the final gear comes out the rear case.
1 - 2 of 2 Posts
