I have what I believe is a 2005 Honda Rancher 450 4x4 with manual shift (please tell me if this doesn’t even exist cause I may be wrong that’s what I was told it was) but it is stuck in reverse. I absolutely cannot get it back into neutral. I pulled so hard on the foot shifter that I actually broke the thing off. So now I definitely cant Shift it. The fact that it is so hard to shift makes me worry I have maybe a gear in the transmission stuck...does this sound like a problem where I will need to dig into the transmission to look for problems? The electric shifter does not work at all on this four wheeler and I dont want to fix that. I just want it to shift normal again. What should my first step be?
your first step is to go back to who you bought it from, and tell them there is no such thing as a 2005 trx450 rancher !!..lol. honda stopped making the trx450 in 2004. what you very well COULD have, is a 2005 trx420 4x4 electric shift ?, I don't know right off hand when honda started producing the trx420's ?, but I deff know you don't have a 2005 trx450 rancher 4x4 with electric shift !.
Reactions: _Wilson_
now that's out of the way, try getting your hands on a service manual. your first thing to try is pulling the electric shift transfer gears out of the front of engine case, and then see if you can some how shift the tranny with some vise grips clamped on the shifting shaft. something tells me the transfer gears up front is causing this trouble ?, or maybe the parts under the front cover ?. but dont pull the front engine case cover just yet !.
also, if you snapped the shifting shaft off so bad ?, your right, you wont be able to shift it at all now, least not until you replace the shifting shaft that you broke off.
So I went back and pulled the electric shift transfer gears out of the front of engine case as suggested but the gear I believe is for the electric shift has actually already been removed...
well, that would explain why the electric shift does not work !..lol.
I am in the middle of a Honda 450S 1999 model currently for the same issue. First thing to do is get the factory service manual and study it. If it is like the one I had to tackle for this problem, the engine will have to come out. Once again get the manual. Be aware that the manual jumps around a little and is had to follow for DIY person. In that event it helps to purchase the Clymer manual. They are a little more DIY oriented.
What I suspect you will find is the shifter plate buried under the front cover has snapped in two pieces. It will require that you pull the front and rear cover off once out of the machine. When you pull the front cover, It is likely you will find the broken part I am talking about. Be careful of all spacer washers. The shifter plate can be replaced without pulling the clutches out but it takes 2 people. 1 has to slowly feed the shifter long shaft through the case from rear to front has you align the shift components. It can be done, but it is tricky. Once all the parts are aligned, the cover can be put back on. Like I said, get the books.
All parts can be found through Cheap cycle parts .com. The parts diagrams are helpful also, so print them off. There is no repairing this in the chassis, it is hard enough to do on the bench.
