1 - 17 of 17 Posts
I'm having trouble with my 2012 Honda rancher not wanting to start. I was driving it and all of a sudden it just died and wouldn't start back up. I pulled the spark plug which I cleaned and then checked the spark which it had. It still wont start just crank. My next guess would be fuel but I don't know where to start. Wondering if I could get some ideas on what it could be. I also checked the fuses and they were all good.
did you check to make sure the fuel is on ?. got plenty of fuel ???. is fuel getting to the throttle body ???.
My 2007 Honda rancher 420 will only start when u spray started fluid into it and I checked it's getting gas to the throttle body need help
please don't post in this thread, when you started another on same topic, I answered you in your thread. it sounds like your fuel injector relay is not working right ?.
Rancher420: You can confirm that it is getting fuel to the cylinder by:
Turn the engine over a few times. Then, pull the plug and see if it is wet (with gas). If it is wet, then you are getting gas. If it is dry, then you are not getting fuel. Also, try replacing the spark plug. I have had spark plugs suddenly fail and I won't go anywhere without an extra plug. Note that Honda gives you a spark plug wrench. However, that wrench/socket doesn't do any good without an extra plug :)
Hey have same issue have replace ,fuel pump, air fule ratio sensor and new injector ,and new battery,, but will run when choked with your hand also new spark plug and fresh gas all switches are in right position helppp
1 - 17 of 17 Posts
