The original Honda OEM oxygen sensor part number was 36531-HR3-A21 and was changed in the past year or so to part number 36531-HR3-A22. In so far as the most common DTC error code 23 for this sensor, which indicates an oxygen sensor heater problem, e.g. either a high resistance or open measurement between the two heater wires (white) on the sensor, the normal readings for the two sensor types between the two heater wires are as follows:
36531-HR3-A21 : 6 - 10 ohms (approximate)
36531-HR3-A22 : 14.5 ohms (approximate)
Several other sources for clearing Honda DTC error codes are covered by numerous other sources both on this forum and elsewhere.
2X ‘16 TRX420FA6G, ‘00 TRX350FE
Thanks for that info, very helpful! I just bought a pair of ‘16 TRX420’s with EPS, barely broken in. And before I had a chance to ride either of ‘em, I’m now getting code 23 on both.
I measured megaohms / open circuit across both white wires on the heater circuit of the sensors on both units, so thanks to your info I know I need to replace them. A handful of short run-times to move, load, unload... I suspect condensation finished ‘em both off.
That said, any idea if the heater in the superseded part number is more durable? I couldn’t find any complaints of ‘18+ models with code 23, which I hope is a good sign.
I’m starting to second guess selling my trusty ‘00 TRX350FE, after seeing it’s not a rare issue.
I did buy the reset tool, its still a pain to use. This site has the info/service manual for the 14 rancher. Same thing as the 16
Yeah, I’d found how to clear the codes. I used a jumper, seemed to have success as I got the flashing, but the code came right back / remained.
Which makes sense as the ohmmeter proved the heaters are open circuit.
Going to grab a couple new O2 sensors and get these quads sorted out. I went for a ride yesterday, and almost all of my doubts are gone.
