I have a 2007 Honda Rancher 420es. I bought it knowing that there was a shift problem. At the time the buttons on the handlebar did nothing when I tried to shift gears. No noise like.it was trying, not even the shift motor was engagining. I took apart The Handlebar switch and saw that there was a couple of destroyed wires. So I order a new handlebar switch. I crank it up and it still doesn't switch gears. It does nothing and the neutral light was flashing. According to the flash pattern, the angle sensor should have been bad. I replaced the angle sensor. It still does not shift. Now the flash pattern says it's the shift motor that's bad. I replaced the shift motor. At this point I attempt to shift and it's a clank like it's trying to shift up but it doesn't actually shift. When I try to shift into reverse it does nothing at all. The
neutral light is not flashing. What should I check next?
Start by trying to shift it thru the gears with the manual tool. If you don't have it an 8mm socket on a 1/4 drive works. Rock the bike back and forth might be needed. Very common to hang between gears. After you have done this shut the key off and on to reset the code. Try it out
I'm having a simular problem with my 09 rancher 420. It'll get stuck in 2nd gear and if I turn the key off then back on it'll let me shift to neutral so I can start it. I replaced the angle sensor, shift motor, and battery. It's still having shifting issues and the mechanics at a Honda repair shop said if you replace the shift motor you have to replace the ecu/ecm. I'm afraid to spend another $300 and that not be the issue! If you figure it out id love to know! Lol
I’m having the same problem here as well, I have a 2007 TRX420 ES model, my grandpa (passed away 3 years ago) had it and passed it down to me, it has ran well over the years, it’s been through a lot, the ES motor isn’t water/mud friendly I’ll tell you that lol. The rancher started having very little bit of shifting problems, when anyone tried to run and drive it all the way to 5th gear, you couldn’t shift back down sometimes so you had to stop and turn the rancher off and back on to get it to reset back to neutral or just rock it back and forth to get it back to lower gear.. The rancher got stuck in neutral one day when we were cutting grass, we just stopped fooling with it, we rolled it and parked it close to our shed, and it’s sat there ever since my grandpa passed.. I’m just now getting around to fix it and so far, it’s been a little rough, 2 gear pieces were chipped off from the gear’s teeth, and to be fair, inside of ES motor was decently clean, not enough grease that I know of, the bearings are surprisingly still in good shape, and I recently got a new battery for it. The only problem I’m having is the manual emergency shifter isn’t shifting up or down, I’ve tried to rock it back and forth but no luck at all, unless I’m not trying hard enough haha. I’ve only been going by some youtube tutorials and it’s helped me a ton because I barely know anything about ES 4 wheelers.. The only question I have is, is it safe to start and let the 4 wheeler run with the ES motor and angle sensor disconnected? I know it’s kinda a dumb question for me to ask but just wondering lol, but from some videos I’ve searched though, I forget what video it was but they say once you disassemble the ES motor and all, make sure to clean and use sandpaper (600 grit might work well) if you need to, use degreaser and let it set about 10-15 minutes and put a small wire brush to it, this process is only for inside of the ES covering. My best bet is to replace the gears, if the little teeth of one gear is broken, then replace both of the gears, one of them almost looks like a shape of a foot and one is round. The teeth of the gear rod that sticks out of the ES motor was broken so I had to buy a new ES motor, but once you get all of the new gears and parts, I heard you have to apply white lithium grease to the gears I’m pretty sure, and apply dielectric grease to the angle sensor, and make sure everything’s aligned correctly, then I think you should be good to go! I hope all works out!
just joined the forums and saw this thread. On my 2012 rancher, rats had gotten into the wiring beside the battery and eaten some of the wires in two. I spliced them back and shifts with no problem. When they were no connected, i could not get it into neutral or hear the solenoid try to engage. Hopefully you have already gotten yours to work, but if not check into this. good luck!
