My machines electric shift does not work. I have put direct power to the shift motor and it does work. I have also manually shifted the machine it it will go through the gears. I believe the angle sensor is ok to. Only thing i think it can be at this point is maybe the actual switch itself but wasnt sure if someone knows how to test that or what else i could maybe try. Hope i gave enough info but if not please ask. It was fine one day and then not the other. I just cleaned the carb and the fuse panel and replaced all fuses. Not sure if maybe it is missing one or not either. Thanks
