Hey y'all, I have a 1989 Honda FourTrax 300. a while ago it started making a clicking noise at starter solenoid so I replaced it. Now it won't do anything, no clicking or anything at all... I CAN kick start it, after I do that the starter will click again after the 4-wheeler is already cranked... Also after I kick start it, the headlights get very dim and flicker. Any idea what's going on??? any help is appreciated!!
Lights flickering , while it's running tells me a week or dead battery, how old is this battery ? I'd OP for a load test, or new battery. I'd hold on to that old sileniod. Was the new sileniod honda oem ?
Do you have a electrical tester? If so we can tell you how to check for voltages. If no electrical tester you can get one at Wally Mart for less than $20 that will allow you to test instead of guess at what might be the problem.
Just a guess but probably the battery.
Old Harbor Freight has a 100 amp battery load tester for around $20 if you get a coupon. (coupons are available on-line)
I'm a electronics tech and have all kinds of testers and find myself using the HF boattery load tester quite often when testing Cycles and Lawn tractor batteries.
