1 - 2 of 2 Posts
Hi everyone,
I'm pretty new on troubleshooting my ATV so the help will be very appreciated.
My problem is:
When I start my quad everything is normal but as soon as I put the transmission to 1(manual mode) D(automatic mode) or Reverse, the regime of the motor raise enough to make the quad moving(what is not what it was doing before) and I can't change the gear to neutral- or 2nd gear. When I turn the ignition (without the motor turning) I can change all the gear without problem but as soon as the motor is turning I can't change the gear anymore.
So in fact if I have to go reverse I have to stop the quad turn the ignition ON put it to neutral start the quad put it to reverse, after that if I need to go foward I have to shut down start the ignition again put it back to neutral start the quad and change my gear to 1 or D to go foward.
I'm not sure if I'm enough clear if you need more clarification let me know.
Thanks everyone!
Discussion Starter · #2 ·
Little update :
I drove it in the street and the throttle is rising up alone I dont touch the gaz switch. I'm able to change speed when I'm driving, I didn't saw any code while I was driving it in the street.
1 - 2 of 2 Posts
