Got a 96 trx200D and want to remove the headlights to replace bulbs - not wanting to have to remove the skid plate or front cargo rack -
How in the heck do you get to the back of these headlights ? - Barely any room for hands up behind them -
Remove the fenders...
Thank you Sam,! . . easier than I expected and gave me the access I needed - Now to rebuild the carb and give it a brake job - Best wishes . .
Be sure to clean the fuel tank at the same time as cleaning the carb. When installing fit a new fuel hose and also an inline fuel filter.
SO MANY carb related threads on this forum and all are usually because the carb isn't cleaned properly/thoroughly and because the fuel tank isn't cleaned at the same time.
Then there's the carb threads where China junk carbs have been fitted..!! Avoid those by the way ;-)
Do you know if the Honda TRX200D Type II has an oil filter and if so where it's located ??
Download the service manual and check parts links in my signature block below
I didn’t see on in the traditional place so please consult manual
