is starts in gear and idles?
is the idle set too high?
Bit of a dog act hey.Hondamatic problems. No simple fixes on these that i know of; sorry but sounds like seller pulled a fast one on you.
Sorry man, it's been awhile, it was starting and idling, idk if in gear or neutral,is starts in gear and idles?
It's been awhile, but yeah, I think esp flashes, but no reverse and I think goes to DSorry I didn't see this sooner.
So does it just not indicate on the dispay that you are in R or D when you move the physical shifter? Or is the problem that it does go into D but is stuck in a high gear ratio?
Does it act as it should when running in ESP mode?
I'm not off-hand what would make it do that. Do you have a copy of the service manual? There is a thread for them on this forum. Then try and retrieve error codes.It's been awhile, but yeah, I think esp flashes, but no reverse and I think goes to D
