I changed the starter Solenoid and the battery ground on my 89 Fourtrax 300 2wd when I started it back up there was some smoke coming from under the front plastic when I cut it of to see what happened I could not find any wires burnt then I tried the start it again now they is no spark at the plug can any of y’all help me out
welcome to the forums. chances are, your c.d.i. burnt up.
James , smoke don't sound too good , no spark and smoke , I am with shade o the CDI -------- did you check the fuses yet , not that I think a fuse is going to fix it , but it might add another piece to the puzzle ---- I think at this point , take off the fender so you can get in there and check the wires , connectors and the back side of the CDI and the coil
