I have 2005 honda forman 500 tm manual shift. It goes into 3rd gear hard then jerks, it also makes a noise when ideling in nuetral sounds like somthing loose in transmission. When backing up on a hill in revers its very hard to get back into 1st gear till I am on flat ground. Could someone help me or have advice. Thanks
You might try adjusting the clutch play. There should be an adjusting screw with a lock nut, on the clutch side cover.
clutch is in good shap. but when rolling in gear i can bump the gas then let off you can fill the slack in the trans. mabe bad bearings dont no for sure. honda wants 1000 just to spit the case . not going to happen thats nuts
unfortunately it sound like some of the cogs on the gears are wearing out (ie rounding) and now the trans will go into gear but it acts like it is jumping out and then going back in just had problem on 400ex had to split case and replaced 3 gears, one shift fork, and the counter shaft bearing. good luck
