I have a 2006 trx500fe and I went riding last weekend and then I noticed the right rear axle nut came loose with a cotter pin in it and I know they were torqued down. How can this happen?
Hmm. Did you mean The nut moved with a cotter pin on the end? You think the entire axle moving outward? To what did you torque it—isn’t it like 100 ft pounds?I have a 2006 trx500fe and I went riding last weekend and then I noticed the right rear axle nut came loose with a cotter pin in it and I know they were torqued down. How can this happen?
Thanks for all the help. Culprit is a bad hub
