I am having issues removing the swing arm pivot bolt that has the jam nut on it. Has any one ever had this issue and what do you recommend.
1. unable to get the jam nut cracked loose
2. I did break a 1/2 breaker bar swivel trying to loosen the 17mm headed pivot bolt
3. I did try heat around the boos of the female threaded area while loosing.
I am going to try a 3/4 breaker bar and 17mm socket set up tomorrow
thanks for any good advice...…!
