Okay so I got an issue with the foreman I just rebuild top and bottom end. It is the ES model so I do have electronic display of my gears. I have a neutral light and a display for first gear. Every other gear the bike shifts into fine BUT there is no display of the gear number nor dash’s. I can run the atv around the yard and it runs great for about a minute and won’t change gears up or down. If you just shut off and turn the key back on you can shift it down to neutral and start the whole process over again. I just replaced the shift angle sensor and replaced the gear position switch.... I’m stumped at this point.
