1 - 10 of 10 Posts
This might be helpful to someone in the future , serial numbers and application chart of engines
Honda Engine Serial Numbers
1000001~ = 1973 atc70
1100001~ = 1974 atc70
atc110e-2000007~ = 1979 atc110
atc70e-2000007~ = 1978 atc70
atc70e-2100001~ = 1979 atc70
atc90e-1300001~ = 1974 atc90
atc90e-1400001~ = 1975 atc90
atc90e-1500001~ = 1976 atc90
atc90e-1600001~ = 1977 atc90
atc90e-1700001~ = 1978 atc90
tb01e-2000013~ = 1980 atc185
tb01e-2100001~ = 1981 atc185s
tb01e-2200001~ = 1982 atc185s
tb01e-3000008~ = 1983 atc185s
tb02e-2000001~ = 1980 atc110
tb02e-2200001~ = 1981 atc110
tb02e-2300003~ = 1982 atc110
tb02e-2500005~ = 1983 atc110
tb02e-2600001~ = 1984 atc110
tb02e-2700001~ = 1985 atc110
tb03e-2000001~ = 1980 atc70
tb03e-2600001~ = 1981 atc70
tb03e-2700003~ = 1982 atc70
tb03e-2800001~ = 1983 atc70
tb03e-2900001~ = 1984 atc70
tb03e-3000001~ = 1985 atc70
tb05e-2000001~ = 1981 atc200
tb05e-2100001~ = 1982 atc200
tb05e-2200001~ = 1983 atc200
tb05e-2300001~ = 1984 atc200s
tb05e-2500001~ = 1985 atc200s
tb05e-2537514~ = 1986 atc200s
tb05e-5000022~ = 1982 atc200e
tb05e-5100001~ = 1983 atc200e
tb05e-5300004~ = 1984 atc200m
tb05e-5400001~ = 1985 atc200m
tb05e-6000001~ = 1984 atc200es
tb05e-6000034~ = 1983 atc200x
tb05e-6100001~ = 1984 atc200x
tb05e-6200001~ = 1985 atc200x
tb05e-6300001~ = 1986 atc200x
tb05e-8400001~ = 1987 atc200x
tb06e-2000033~ = 1981 atc250r
tb06e-2100004~ = 1982 atc250r
tb06e-2200005~ = 1983 atc250r
tb06e-2300003~ = 1984 atc250r
tb06e-2400001~ = 1985 atc250r
tb06e-2500001~ = 1986 atc250r
te01e-2000014~ = 1984 atc125m
te01e-2100001~ = 1985 atc125m
te01e-2200001~ = 1986 atc125m
te01e-8300001~ = 1987 atc125m
te04e-5000001~ = 1985 atc250es, atc250sx
te04e-6000001~ = 1986 atc250es, atc250sx
te04e-7005001~ = 1987 atc250sx
te04e-8100001~ = 1987 atc250es
te04e-????????~ = 1988 atc250es
te08e-5000001~ = 1985 atc350x
te08e-5100001~ = 1986 atc350x
us90e-100122~ = 1970-1971 us90
us90e-200001~ = 1972-1973 us90
thanks fish, if these can be verified ?, ( as in..some folks check them maybe ? ), i'll make this a sticky :).
Jeep , on a 300 it is on the right side top of the case in a square box , same on a TRX250A , the 450 is on the upper , left rear crankcase , can't see with the covers on , I have a 500 in the yard of a friends right now and you can see in the pic , you can't see nothing , would guess it is the same as the 450
here is a chart of the TRX450 engine serial numbers
1 - 10 of 10 Posts
