Better tires and 12 inch rims on the back. I had 2 flats on the first trail ride at the farm.
That's a big one right there for the Rancher..
This is what I was on about Mac, I've considered getting one myself.I know, I've ran a TinyTach before. But it's a lot easier when it's already there lolYou can buy aftermarket Tach's/ rev counters. Check eBayUK out.I don't think adding more gauges will leave you walking back to your truck.....
Tach is a VERY handy tool for tuning. Almost irreplaceable really. It's a lot easier dailing in your fuel map when you know what RPM the engine is at.
EBayUK item number 142112145258
So you would be fine not having anything other than idiot lights and speedometer on a pickup?why would you need a tach on a semi-automatic motor ?, that's like having it in my automatic transmission in my '00 Silverado ?, freaking useless for the most part.Full set of gauges would be cool. Hell even just a tach would be handy.
never said anything about the idiots lights ?..I SAID TACH !!..LOL. no automatic tranny should have a tach, unless your stickily working by the book ?. you don't need a tach for an automatic transmission ?..it aleady knows when to shift while in D, correct ?, it also has tow mode, knows when to shift then ?, a tach is worthless on a automatic, heck, I never even used it when I was driving a standard transmission truck ?, if you can't shift gears by ear ?, you don't need to drive a standard !..lol. ever wonder how many truck drivers ( real truck drivers that drive over the road ) use their clutch ??. I know a lot that never touch it, cept when in town ?..lol.So you would be fine not having anything other than idiot lights and speedometer on a pickup?why would you need a tach on a semi-automatic motor ?, that's like having it in my automatic transmission in my '00 Silverado ?, freaking useless for the most part.Full set of gauges would be cool. Hell even just a tach would be handy.
I know I'm not. I use my truck as it was designed. To pull trailers, plow snow, haul my four wheeler. I like to know if my plow is causing it to overheat or draining the battery down. Same thing with the trans temp.
What difference does it make if it had 1 gauge or 10? If a gauge fails it's not like you will be walking home lol
I'd spend the 12-13k that quad would probably cost and I'm sure a lot of CanAm and polaris owners would be willing to make a switch too. Even if it didn't get a bump in power, a 4x4 version would probably weight in at about 560lbs wet. that would be a hell of a quad with 55HP and a 5speedHow about a 4wd 700XX with about a 30hp bump in power while using a 5 speed semi auto....
That's kinda what I was thinking, 600# wet or so, even 650# I could live with. @55hp and a 5 speed it would be pretty comparable to a 70-75hp CVT quad with the difference in power loss through the drivetrain. But, I've never been one to settle for "comparable" lolI'd spend the 12-13k that quad would probably cost and I'm sure a lot of CanAm and polaris owners would be willing to make a switch too. Even if it didn't get a bump in power, a 4x4 version would probably weight in at about 560lbs wet. that would be a hell of a quad with 55HP and a 5speedHow about a 4wd 700XX with about a 30hp bump in power while using a 5 speed semi auto....
If you didn't have a tach on your CVT auto you'd never be able to find out what your shift out RPM is, or your redline, or like I said earlier it's REALLY helpful to know what RPM your at when your trying to make a fuel map. You seem to be fixated on the "fact" that you only need a tach to know when to shift, and is therefore useless with an auto transmission, and that is a ridiculous conclusion to come to IMO.never said anything about the idiots lights ?..I SAID TACH !!..LOL. no automatic tranny should have a tach, unless your stickily working by the book ?. you don't need a tach for an automatic transmission ?..it aleady knows when to shift while in D, correct ?, it also has tow mode, knows when to shift then ?, a tach is worthless on a automatic, heck, I never even used it when I was driving a standard transmission truck ?, if you can't shift gears by ear ?, you don't need to drive a standard !..lol. ever wonder how many truck drivers ( real truck drivers that drive over the road ) use their clutch ??. I know a lot that never touch it, cept when in town ?..lol.So you would be fine not having anything other than idiot lights and speedometer on a pickup?why would you need a tach on a semi-automatic motor ?, that's like having it in my automatic transmission in my '00 Silverado ?, freaking useless for the most part.
nope, my speedo's never failed on my trucks..lol. as for what and when to shift on a auto ?. well smart guy...that's what the damn ecm is for !..lol. as I said, unless your working on your truck by the book ?..the freaking tach is useless !. is for me anyway, you want one ?, by all means..get-r-done !, me ?, nope..don't care for that extra crap that servers me no reason for being there, other than taking up space for my idiot lights ?!.lol. and wth has redline got to do with a tach ?, when your shifting by ear and feel !!..lol. wow mac, surely your smarter than this ?!..lol.If you didn't have a tach on your CVT auto you'd never be able to find out what your shift out RPM is, or your redline, or like I said earlier it's REALLY helpful to know what RPM your at when your trying to make a fuel map. You seem to be fixated on the "fact" that you only need a tach to know when to shift, and is therefore useless with an auto transmission, and that is a ridiculous conclusion to come to IMO.never said anything about the idiots lights ?..I SAID TACH !!..LOL. no automatic tranny should have a tach, unless your stickily working by the book ?. you don't need a tach for an automatic transmission ?..it aleady knows when to shift while in D, correct ?, it also has tow mode, knows when to shift then ?, a tach is worthless on a automatic, heck, I never even used it when I was driving a standard transmission truck ?, if you can't shift gears by ear ?, you don't need to drive a standard !..lol. ever wonder how many truck drivers ( real truck drivers that drive over the road ) use their clutch ??. I know a lot that never touch it, cept when in town ?..lol.So you would be fine not having anything other than idiot lights and speedometer on a pickup?
Have you ever had the speedo fail and had to drive by the tach readings? lol Guess not.....
fine, i'll speak of Honda atvs, hows that ?, you will never see Honda put a tach on their atvs , why ?, because they program the shift points into their ecu's..thats why !..lol. in case ya missed it ?, most all newer atvs are controlled by the computer, sensors for the most part, which controls the ecu. again, I don't need a stupid tach for a semi-auto tranny on an atv ?, you may need it ?.as for the redline crap ?..it's built into the ecu rev limiter..no tach needed..lmfao.#1 I don't care when to shift an auto, like I said, how can I find out my shift out rpm for tuning my clutches in a CVT auto without a tach...
#2 I don't often work on my trucks, I have had speed sensors fail, I have had to guess my speed by rpm, which I wouldn't be able to do with no tach. We of course are talking about ATV's, but you keep bringing up your truck sooo?
#3 Yes I do do a lot of things "by the book" I've never used a tach for setting the idle mainly because I prefer to run EFI machines which do not have an adjustable idle speed.
#4 "What does a tach have to do with redline" Well, for starters how would you have any idea that your redline RPM is without a tach? Higher RPM means faster wheel speed, how do you know your getting your money's worth out of a rev box without being able to look at real world numbers. I know I operate on space ship technology here but say I go into the tuning on my machine and add another 500rpm to the max RPM, how would I ever know if I got it without a tach?
Arguing over how you don't need a tach is foolish, you'll never buy a new Honda anyway, so whether they dedicate 1" of the screen for a RPM readout or not shouldn't make much difference to you. But I tell you what, if Honda ever does start putting tachs on, and you somehow end up getting one, feel free to put a piece of tape over the RPM section and don't forget to come back here and brag to us about how you don't need a tach....
Well if an auto truck doesn't need a tach then why does it need all those other gauges?never said anything about the idiots lights ?..I SAID TACH !!..LOL. no automatic tranny should have a tach, unless your stickily working by the book ?. you don't need a tach for an automatic transmission ?..it aleady knows when to shift while in D, correct ?, it also has tow mode, knows when to shift then ?, a tach is worthless on a automatic, heck, I never even used it when I was driving a standard transmission truck ?, if you can't shift gears by ear ?, you don't need to drive a standard !..lol. ever wonder how many truck drivers ( real truck drivers that drive over the road ) use their clutch ??. I know a lot that never touch it, cept when in town ?..lol.So you would be fine not having anything other than idiot lights and speedometer on a pickup?why would you need a tach on a semi-automatic motor ?, that's like having it in my automatic transmission in my '00 Silverado ?, freaking useless for the most part.
