Has anyone swapped the tires and wheels of a Honda 420 on to a two wheel drive 1989 300 four trax? I have a chance to get the stock wheels and tires but not sure if they will fit due to my 300 having drum brakes.
The bigger question is if they are from an SRA or IRS 420. SRA will have the correct offset, IRS will not. Either will "fit" but offset is just as important.
Welcome to the forum.
Reactions: Vaughn726
I am a 300 guy and not a 420 guy , the bolt pattern will be the same , 420s were available with straight axles and IRS , the IRS rims would have a different offset and could work if you used wheel spacers , the straight axles will be the same offset or close enough
