Hi guys, new to the forum and having similar issues to Dbruce (not running well post in 2019) but have a feeling its not the fuel pump psi here as its a new pump fitted, started having what i thought was fueling issues a few weeks back, quad would start but not sit in take over, would run for a few seconds, go lumpy and stall. so started a process of elimination with the following;
can angle sensor lead to lumpy running? should i check the timing? if so how? im not a novice around a quad but engine internals is something else....... could i have over sea foamed it? thanks guys.
- checked and cleaned the IACV
- removed and cleaned the fuel injector (and checked was it working which it was).
- replaced spark plug
- new fuel filter
- new fuel pump and fuel filter
- new ignition coil
- removed fuel tank, flushed and cleaned both tank and internal filter.
- Added sea foam to fuel tank
