Hello, I've searched extensively here and online other places, and cannot find exactly the same issue.
I have a Honda fourtrax 400, I believe late 90's, and it wouldn't start or have power at all to like the neutral light.
I jumped the starter solenoid, and wala, it turns over and starts. So.....I replaced the solenoid thinking that was the bad part. The brand new solenoid is in, and same thing, no power, but I can jump it. Any suggestions? Thank you
Just had the same problem with my 87 TRX 250 if it's the same I had a bad connection under the front plastics near the auxiliary fuses. I would check n be sure you don't have more fuses you aren't aware of. Mine are located under a small removable panel just in front of the handlebars.
