after my last post, I bit the bullet and went for an full rebuild motor rebuild. since I had an atv wreck back in early May, I was not able to do much with the Fourwheeler. After I took the motor to a local machine shop and got all the clearances and what not delt with. now that The Fourwheeler is put back together, I am having some problems with the carb not working correctly. when I start it. it runs wide open even with the idle screw as far down as it will go. Yes, I have cleaned the carb multiple times now. just today I took all the plastics off the sides and I took off the factory snorkel, alone with the air fiter off and It runs okay.
And also since I had rebuilt the atv, it doesn't sound like it use to before this top end and bottom end.it sounds like timing is off but I put a new chain and tentioner along with guides in it. Just thought if I could kill 2 birds with one stone. that it would be better then making 2 Threads about this.
