So my 2006 Honda 350 fm is having an issue where the neutral light doesn’t come on. I’ve shifted into neutral, checked all the fuses, the battery is good and still no neutral light comes on when I turn the key. I found the neutral safety switch connecter and hooked an alligator clip to the green and red striped wire and put the other end of the alligator clip to the negative side of the battery and nothing happens. I put an alligator clip to the gray wire and put the other end to the negative side of the battery. Nothing happens. I can put the alligator clip to the positive side of the battery and the reverse light on the dash will come on. I tried doing the green and red stripe wire to the positive side of the battery and the light doesn’t come on that way either. So neither the negative or positive side of the battery will turn the neutral light on. Only the reverse light works but only on the positive side of the battery.
