1 - 20 of 24 Posts
i got a honda 300ex we put a new cam and rocker arms in the motor we put it all back togather and it started and run after a couple days i went to ride it and it wouldn't start it turns over but wont start i also cleaned out the carb does any one k now what might be wrong with it thanks
Do you have spark?Is it in reverse by chance?
Oh the 250's just have no spark in reverse.
Try re adjusting them to .004 intake and exhaust , make sure your at TDC when you do it. I think you may be right?
When you installed the cam you did put it in Lobes down right?
Your timing chain wasn't stretched, was it? It might have jumped time.
Discussion Starter · #12 ·
nope its tight we had a guy do it for us that worked at a honda shop so the timing should be fine now when i put the new rocker arms in i adjusted them but should i also adjust the vales also
Adjusting the rocker arms is the same thing as adjusting the valve clearance. That's how you adjust the valve clearance, is by adjusting the rocker arms.
Discussion Starter · #16 ·
the cam is used but like new and the rocker arms are new i didnt really get to brake them in Caz it stopped running before i got to brake them in
k im lost man there is no reason it should have died already! I was gunna say if it was a aftermarket cam it would need hardened rockers or the idle screw may need turned up?
Discussion Starter · #20 ·
ya been trying to figer it out i don't under stand why it died but im going adjust the vales again and see if every thing is tight thanks for the help
1 - 20 of 24 Posts
