I have a 92 300 with a 250 rear end with brake delete , the differential and axles tubes are packed with grease , I am not a fan of the brake delete , seems to me there is no seal protecting the bearings once the brake cover seal is removed ---if not for the hub paddles I would stick have a brake on the rear ---if I were going to do a brake delete I would run grease and not oil and drill and tap the tubes and fill them full of grease also ---something I do when I check the oil in the rear diffs or re-pump them full of grease as I have a mix of both oil and grease diffs , is to pull the plug on the brake drum cover to check for water , if water has made in it to the drum then I know it is time to change the seal
