On my honda 300 I can pull the shifter up and keep the shift lever up and the clutch doesn’t engage does anyone know how to fix that ?
Did this start after an extended time of storage?
No I just put new clutch plates on it and I put them on right so I don’t know what’s wrong with it
OEM plates or aftermarket?
Try adjusting the clutch adjustment screw right next to where the oil filter goes. Loosen the nut, back the screw out un till you hit resistance, then turn it in 1/4 of a turn keep your screw driver on the screw as you tighten screw so you don't make it out of adjustment again. See where that gets you. Hope this helps!
