I believe you're right. It seems like I can remember some kind of modification that you have to do to them, but I couldn't remember what it was.Unless they have changed the design of them you used to have to grind away some bolts in the engine just to get it to fit. So I personally don't like them.
ok I PMed him. So far I have jetted the carb with a K&N filter and a clutch kit for performance. Its doing alot better than stock but Im still needing just a bit more. Ive noticed reverse had to be lower geared than first gear because it will spin in anything easily. So thats why im thinking a gear reduction will help.PM "gotmuddy" over on the highlifter forums, he makes them or he used to, I guess he still makes them.
Just click on the link below and type "gotmuddy" in the box and hit search, then you can PM him.
High Lifter Forums
Yeah, it does feel about the same. I wouldn't have known it if I hadn't seen it on paper.humm, good to know. it feels the same.
