Start with the simple stuff... check fuses & diode (if equipped), wiring harness plugs (especially at the neutral/reverse switches on the motor), frame ground, kill switch, ignition switch etc. Once the neutral light is working it'll probably crank over and start.
Welcome to the forums!
