I once stayed at a Holiday Inn too, even left all of the towels & remaining soaps and toilet paper in the room! :)
Check the motor oil level on the dipstick 1st. Note the color of the oil... does it look clean or is it blackened? Fill it to the proper level if it is low. Then take the oil filter cover off and make sure that the oil filter wasn't installed backwards by the owner (or yourself?) during the last oil change.
If all appears well so far, you'll have to determine whether the clutch is fried (most likely) or the Hondamatic trans (next likely) is damaged. Report back with your findings.
Welcome to the forums!
Remember that commercial , there were so many of them , one is like a guy getting an open heart surgery and he asked the guy with the knife that is about to cut him " are you a doctor ? " and the guy says " no but I stood at a Holiday Inn last night "
This must be US humour as I have absolutely no idea what your on about, either that or It’s before my time!
Lol...before my time too :p
Sounds like it could be the oil level like retro said. Had a couple of these & if it was low, the trans would make a grinding scraping noise. Make sure you check it with the dipstick out. If that isnt the cure, post your results.
Mechanical sympathy at it's finest :wink
Just couldn't resist posting that :grin
