1 - 14 of 14 Posts
I got a 400ex about a week ago I know it's got a hotcam and aftermarket exhaust and it's not running right you wonder if anybody knows what size Jets I should put in it to make it run right. And I'll let you know what it's doing it won't idle good and it's on the top end it keeps it wants to stutter. Any help would be great
If its bored 40 over its not a 440. That would mean it was bore 40 thousandths of an inch. A 440 would be a 89mm bore. From a stock 85mm. In all honestly to properly jet a engine we need to know what has been done to it. Without that were just guessing. We also need to know what size jets are in it. If its .040 over you will want a 42 pilot jet for starters. That will solve start and idle problem. If its a 440 minimum of a 45 pilot jet. Probably a 48. Main jet will be trial and error until you get it stop popping on decel. Drop the needle clip one slot down(closer to the pointed end)
45 pilot and 148 main? If you had a 48 main jet in it and it revs at all i would be shocked. If its a 148 main that is stock size. Did you drop the needle clip?
Ok. Again we are just guessing since were not sure if its a 440 or not. But i would say put a 175 main jet in it and drop the needle clip down one slot.
1 - 14 of 14 Posts
