1 - 9 of 9 Posts
I have a 06 rancher 350. Im rebuilding the bottom end and im unable to get the 2 cases back together. for some reason they bind up the cranckshaft and tranmission when bolted together. then i will not spin. i have taken it apart and back together again 7 times and cant figure it out. someone please help! Thanks
hmmm.this is kinda hard without standing there and watching it..lol..all i can do is go over how i did my 2000 trx350tm rancher..maybe it will help you. with the rear lower case layed on it's side facing up..install your transmission..crank and crank shaft balencer,,make sure all your transmission gears are right..and facing the righ way..you should have your shifting drum installed also..with all these inside the case..make sure your index mark is lined up on your crank and crank balencer !!..after everything is installed..get the conecting rod up through the top of the case between the studs..if you got it all together right..the other half should just drop right down onto the one side..if not..something isn't put in the lower case right...and it's not lining up into the bearings for the top side...not sure if you have a service manual..but it sure helped me get mine back together.
hmmm.this is kinda hard without satnding there and watching it
Yeah, that's my exact thoughts, too. If you're not there looking at it, it's hard to give any advice on these types of problems.
yeah..i hate to sound like that helmut..but..there isn't alot i can do without putting my hands or eyes on it..seeing how the cases aren't going together..anything could be binding..stopping it from going together.
Yeah, I know. To be honest, that's why I haven't replied to this thread. I just didn't know what to say because it could be anything. No way of knowing unless you're there looking at it.
i totally agree helmut. unless were looking right at it..there isn't alot we can do..i guess you could say..it's a discover yourself why it won't go together??..sounds cruel..but..it's honest.
if i remember right..i think he said something about he was gonna use another engine from a different atv ??..if thats the case..i hope he checked to make sure eveything matched up..as like..the crank was the same length..shifting drum ..all of it.
Thanks guys, i had a brain fart.i had one gear upside down! it went toghter nicely. I was about ready to throw in the towel.. it took 10 hrs to figure that out. DUH!
lol bro..done the same damn thing on my '96 trx300fw..buttttt..i was going by the book damnit !!..lmfao..it's not my fault the pic's aren't clearer !!..lol. glad you fixed it..oh..and i did mention to check to make sure your gears were not on upside down i think ?..lol.
1 - 9 of 9 Posts
