1 - 18 of 18 Posts
Hey guys im kinda new to this site and i was wondering if you guys can help me with something. I have a 2003 honda250ex and i bought it used but when i got it home i found out that the foot break did not move at all. If any one can help me find out why this is and how to fix it it would be much help.:sad:
Could be frozen up with rust.Get some pb blaster from auto zone and keep spraying it around the edge of the brake spindle.Good luck.
Yep no problem man.
Yeah, if it don't come loose that way, you may have to pull the brake pedal off and take some fine sand paper or emery cloth and get the rust off. Then, just put a little white lithium grease on the shaft and put it back on.
Maybe the master cylinder is seized up.
Does it have drum brakes or disc brakes? If it has drum brakes, it won't have a master cylinder, just a cable. The cable could be stuck. It might need replaced or the brake shoes might be seized up.
I would spray some PB Blaster on it and try working the pedal up and down with your hand and see if it will work loose. Sounds like its froze up or in a bind.
Yeah, I agree with mud. Your pedal has seized up. Try what mud said and if that don't work, you may have to remove the pedal, clean the rust off with sandpaper or emery cloth, and then put some white lithium grease on the shaft.
1 - 18 of 18 Posts
