Help
2603 Views 23 Replies 6 Participants Last post by  TRIPLE7
I just bought my son a 1986 Honda trx 125. When I first got it you could pull start it (dead battery) and it would run ok. I bought a battery and put in a new carb kit and he rode it all day. That night I put it on a trailer and drove to the deer lease. Got there and couldnt get it started. I thought that the carb had trash in it so I bought a new carb and installed it. I noticed that the spark plug wasnt getting constant spark. It seemed that it would spark a few times when you hit the start button then stop, it would then spark a few more times when you let off of the start button. I had the ignition coil checked and they said it was good. My next guess is that the pick up coil is bad but I checked it with an ohmmeter and I am getting a readying of around 100, not sure what it should be. When I push the start button it turns over and every now and then it will fire off for a few seconds. I just dont think that I am getting a good spark. Any ideas??????
21 - 24 of 24 Posts
IF IT STILL SPITTIN AND SPUTTERING SHOULD I ADJUST THE NEEDLE HIGHT TO KEEP IT FROM BEING TO RICH. i WILL CLEAN THE JETS TONIGHT/
ok, I went back through the carb and cleaned the jets. They looked ok but I cleaned them anyway. I let the carb soak in cleaner all night and put it back on this morning and it purs like a cat. I can push the throttle and it responds well. However when I put it in gear and start to drive it dies. Any ideas?
Idle too low? did you set the pilot? I think I said 1 1/4 turns out from seat try another 1/4 to 1/2 turn then reset the idle. you want it just high enough so when you engage the shifter it dosen't jump profusely, it will jump a little. my 110 does it. You did clean or replace the air filter didn't you?
I adjusted the idle a little bit more and it seems to working well. I put a new air filter on before I started. Thanks for all of your help. It's really cool to have a place like this.
21 - 24 of 24 Posts
