1 - 10 of 10 Posts
I have a 2005 Honda Rancher 4X4 350. It has the manual shifting only and the gears seem really tight or difficult to change. I have tried to adjust the clutch but it didn't seem to help. Can anyone offer advice? Thanks.
adjusting the clutch only takes the free play out of the clutch disk..it will not let the bike change gears easier...if your having issues with the gears not changing easy..sounds like a tranny issue..or something is binding up your shift arm..shift arm wheel..or maybe both..you could have a broken return spring also..< this makes the shift arm move easier >....sounds like 1...you need a repair manual...2..your gonna have to tear into it to see why it's hanging up so bad..good luck..keep us posted !
are you sure you did the clutch adjustment right?if you turn the screw the wrong way your clutch will not open up all the way,the best way to tell if you are adjusting it the write way is to turn the adjusting screw in one way a few turns ,then lift up your shift lever a little bit,you will notice that when you turn the adjusting screw in you will increase the slack on the shift lever,turn the screw the other way the slack will decrease.you want to decrease the slack on the shift lever,turn the adjuster counter clockwise until it stops then back it off 1\8 turn and tighten the lock nut.
For what it's worth, the 05 Rancher I used to own did the same thing but only while the engine/transmission was "cool". I say this because after it warmed up, if shifted fine. Seemed like it only did this after it sat for any length of time.
Also, my son's 09 Recon does the same thing but is getting better the more he rides it.
you got oil in there made for wet clutches? i had a 97 forman, standard, sometimes she would get hung up with the wrong oil.
I have a 2007 honda rancher trx420 fe the other day I was riding it with no problems when I stopped and put it in reverse I backed up and shifted into into 1st gear went about 15 feet shifted into 2nd gear the fourwheeler wouldnt move I couldnt up or downshift it has electric shift I tried using
The manual shift tool I could not get it to shift at all unsure what happen any help would be great thanks in advance.
For whats it's worth many folks say that switching to synthetic oil (for cycles) can help. A friend's 04-05 350 Rancher has been hard to shift since new. He recently switched to synthetic and reports it now shifts pretty smooth..
I'd check to make certain I was using a wet clutch spec'd engine oil as it could be causing the clutch to act up if it isn't wet clutch spec'd oil..GN-4 only in these engines people...
If you couldn't get it to shift with the manual shift tool, then you have a tranny problem or a shift linkage problem. More than likely, it's a shift linkage problem. I would pull the front crankcase cover and inspect the shift linkage and the shift motor reduction gears. If you don't have a service manual, go to the manuals/schematics section and you can download one.
1 - 10 of 10 Posts
